It is currently Mon Aug 11, 2025 7:59 pm
PostPosted: Mon Sep 26, 2016 8:17 am
Has anyone ever had this happen? It just turns itself off and then you can hear it click back on a few minutes later. It does feel quite hot to the touch. It seems to do it when loaded, but has also done it when it's just free spinning.
It's a Balder 1/3 hp that is not terribly old, but I did buy it used, so I don't know how much use its had. I used it for a couple previous projects and I do not remember this happening.Image
PostPosted: Mon Sep 26, 2016 8:30 am
Have you looked inside to see if it's full of buffer fluff?
These users thanked the author Chris Pile for the post: Rod True (Mon Sep 26, 2016 9:16 am)
PostPosted: Mon Sep 26, 2016 8:35 am
Nothing to offer, but I see Hardwick on the sticker. I love that store.
These users thanked the author Pat Foster for the post: Pmaj7 (Mon Sep 26, 2016 8:51 am)
PostPosted: Mon Sep 26, 2016 8:52 am
No, is that something that typically happens?
PostPosted: Mon Sep 26, 2016 9:17 am
I was going to say the same as Chris. Also, how tight is the belt.
Take the belt off and run the motor for 10-15 mins. Does it still get hot?
If not then it's something with your buffer set up. The bearings might be non-concentric which will add to the load on the motor. With the belt off can you free spin the buffs easily?
PostPosted: Mon Sep 26, 2016 9:23 am
All good suggestions. Also, double check your wiring, make sure all of the connections correct and tight.
PostPosted: Mon Sep 26, 2016 11:01 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
I may be mistaken, but is that motor an open, drip-proof type? If so, all of that buffing wheel fluff, dead compound, and any other debris in the air is passed through the interior of the motor with the cooling air.
Perhaps after cleaning out the motor, you might consider seeing if there is a used, totally enclosed, fan cooled motor available from your vendor and work a swap. While a TEFC motor still needs to have the fan plenum and fan cleaned out with compressed air every few months, it is much easier to keep clean and running cool than an ODP design.
- Beth Brower
PostPosted: Mon Sep 26, 2016 3:20 pm
I will check all of those things tonight. Although, I was hoping I wouldn't have to open it up! I'm not sure if it is a certain type of motor or not. How would I tell?
PostPosted: Mon Sep 26, 2016 3:47 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
That isn't a TEFC motor, which is what you would like to use in this application. I've heard of people putting a lady's nylon over the motor to keep the dust out, but once it gets covered in dust, your motor will over heat, or something more dangerous might happen.
Alex
PostPosted: Mon Sep 26, 2016 3:52 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Possible capacitor failure?
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Mon Sep 26, 2016 5:31 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
Just take it to an electric motor repair shop. They'll probably fix it for $15-$20 (probably a capacitor).
PostPosted: Mon Sep 26, 2016 7:31 pm
First name: Rob
Last Name: Roither
City: Williamsburg
Zip/Postal Code: 23188
+1 on overheating. The click you hear is the thermal protection switch closing after enough cooling.
Probably not a bad capacitor; since that's a start capacitor, it's taken out of the circuit as soon as the motor gets up to speed. The motor wouldn't start if the capacitor was bad.
PostPosted: Mon Sep 26, 2016 8:54 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I/d would have the wiring checked for the circuits overloading somewhere in the wiring.
PostPosted: Tue Sep 27, 2016 11:56 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Is it wired correctly in terms of Low vs. High voltage?
I'm not a luthier.
Users browsing this forum: Chris Ensor, J De Rocher and 25 guests
